ZINC & COPY CAD CONCENTRATE - MAKES 39G
Mix 13 ounces of part A with 36 ounces of Copy Cad/Zinc Part B and 1.5 gallons of distilled water. Refer To Manual For Complete Instructions.
GHS Info
SDS
