ZINC BRIGHTENER ADDITIVE - 4 OZ
For use with Caswell Zinc Plating Process
Add 1/2 teaspoons per 1.5 gal of plating solution.
When plate becomes dull, add another 1/2 teaspoon.
***Do Not Add Entire Contents. ***
Use Sparingly.
SDS
9 Reviews Hide Reviews Show Reviews
amazingly bright
this allows a super bright mirror like finish to show through works great. needs replenishing very often so be prepared!
Great Product
I use the copy cad and zinc plating kit and it works great!
Flip the Copy CAD switch
Really great that the Zinc plating materials from Caswell can emulate Cadmium plating and then produce the brightest Zinc with addition of this product
works as advertised
a little dab will do ya!
Great product
90% of everything i bought from Caswell worked like a charm.Great product from great people.Now if somebody can tell me how to get the green drab to work??? No luck there!!
Zinc brightner
Excellent imitation on cad , easy to use. Prep work is the key to a good finish.
bright like a diamond!
this stuff really makes bolts pop with a shine!
awesome products! I always have the best looking finishes when using your products!
Excellent product. Easy to use a produces an great finish.
