These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
SDS
3 Reviews Hide Reviews Show Reviews
Nice rich color
Really nice bright copper look.
Thanks for the prompt service
EXCELLENT seller which is why I continue to buy from!!!
Caswell Copper BF Dye
Nice dye, easy to adjust shade. I prefer 12 minutes for a deep copper look, but 4 minutes gives a gold looking shade.
