HAZE REMOVER POWDER - 8FLOZ
Specially formulated powder removes light compound residue and haze, allowing for close inspection of the polished part. Helps remove those annoying micro-fine scratches.
Sprinkle on the part and wipe off with a soft cloth, microfiber cloth or microfiber glove.
SDS
3 Reviews Hide Reviews Show Reviews
My favorite supply site great polish stuff
Another Excellent product
TAKES AWAY HAZE NO PROBLEM!
USE WITH A MICRO TOWEL
EXCELLENT
DOES WHAT IT STATES!!! GOOD STUFF
