Cartridge rolls are cylinders of abrasive cloth, which allow a new cutting surface to be uncovered as each layer is worn away. Good for cylinder head polishing, flash removal, deburring, tool-mark removal, wood carving and more. Aluminum oxide resin-bond with cloth backing assures trouble free, long lasting performance, even at speeds up to 20,000 RPM.
