Cartridge rolls are cylinders of abrasive cloth, which allow a new cutting surface to be uncovered as each layer is worn away. Good for cylinder head polishing, flash removal, deburring, tool-mark removal, wood carving and more. Aluminum oxide resin-bond with cloth backing assures trouble free, long lasting performance, even at speeds up to 20,000 RPM.
Starter Kit contains:
- Precision machined, cold rolled steel mandrel (1/4" Shaft, 2.5" long)
- 6 cartridge rolls (1/2" dia x 1" long)
- 1 x Fine (120 Grit) Tapered Roll
- 1 x Medium (80 Grit) Tapered Roll
- 1 x Coarse (60 Grit) Tapered Roll
- 1 x Fine Regular Roll
- 1 x Medium Regular Roll
- 1 x Coarse Regular Roll
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
small sanding rolls
great product and price.
