BUFFING WHEEL CEMENT - 1 GAL.
For use with the Aluminum Oxide. Using a knife or spatula, the thixotropic adhesive is spread evenly around the face of your wheel.
Roll the wheel into the abrasive using light pressure, ensuring a heavy pickup of the abrasive.
Leave the coated wheel to air dry for several hours prior to use. Subsequent applications will provide a longer lasting system. Gentle heat from an oven will speed up drying times considerably.
As the system wears off, the wheel may be retreated numerous times.
SDS
