Brush Plating Connecting Leads
- Fits 3, 5, 10, 20, 25, 50 and 60 amp units above
- Red Lead with two banana plugs for unit to plating wand connection
- Black Lead with one banana plug and one alligator clip for unit to work connection
- 6' length
- 16 gauge wire
good product
All of my purchases from caswell always arrive before stated date. They als arrived in good condition as I have recieved broken stuff from other vendors. I do recommend Caswell for your plating needs.
nice set
Works and is a nice replacement.
