These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
GHS Info
4 Reviews Hide Reviews Show Reviews
                Thanks for the prompt serviceVery fast transaction and a great product
                great colorThis color almost turns out with a coppery tone to it. Very cool color.
                Nice colorI use this color for bronze, brown and a light gold color.. it's very versatile. Was able to make a wood like look. Love it!
                Good colorThe dye absorbs well and like all caswell dyes, can be used with longer/shorter times to make different shades of the color. I will be buying some more eventually.
