Bronze Plating Kit
Our new bronze plating system provides a beautiful, rich bronze finish without any dangerous cyanides or other hazardous chemicals. The coating is suitable for decorative applications.
It will plate over Zinc Castings, Pot Metal, Pewter, Electroless Nickel, Plated Nickel, Copper, Steel, Sintered Metal, Tin, Lead, Stainless Steel and Zincated Aluminum.
It is recommended to activate Zinc Castings, Lead and Pot Metal in Pickle #4 prior to plating.
The bronze plating solution comes pre-mixed and ready to use. Plate with stainless steel anodes at 80°F, with 3V and 0.07 Amps per Square Inch.
A 2-3 minute plating time provides a good color, which may then be clear coated for corrosion resistance. If buffing the bronze plate is required, plating time should be increased to 30-40 minutes.
1.5 Gallon Kit Contains:
- 2 x 2 Gal Tanks and Lids
- 2 x Stainless Steel Anodes
- 1 x 4 Gal SP Degreaser
- 1.5 Gal Bronze Solution (pre-mixed)
- 1 x Filter Pump/Agitator
- Caswell Plating Manual
- Free Technical Support
- NO HEATERS INCLUDED
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
GHS Info
SDS
All Good Except the Circulation Pump
This is the 3rd kit I have purchased and the second one that has had the little white plastic impeller in the circulation pump break within a few days of use. It is the only part of the pump not covered by the warrantee. I am beginning to see why.
