These professional quality anodizing dyes provide consistent, quality results. The same dyes are sold to professional anodizing shops all over the world. 4oz of dye concentrate makes 2 Gallons.
These colors are approximate. The finish will normally have a more 'metallic' look, and will vary slightly depending on the alloy and surface preparation.
Procedure for Obtaining Dyed Anodize
Anodize the aluminum at 60-75°F for 90 minutes at 4.5 amps per sq foot or 0.03 amps per sq inch. Use our Anodizing Kit.
After thorough rinsing, immerse the part in the dye at a temperature of 140°F for 15 minutes.
Finally, seal by hanging the part in a sealer bath for 15 minutes.
All dyes are fully ROHS compliant.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
GHS Info
![](/content/images/ghs_harm.png)
SDS
3 Reviews Hide Reviews Show Reviews
Nice color, but pay attention to alloy
This dye makes a deep rich color, but watch the alloy. I had four parts to match. The 7075- T5 parts that came out very deep, closer to black, in 70 seconds. I had a 6061- T6 extruded part that was dyed for 20 minutes but didn't get quite as dark. No problem with the product, just something a novice such as myself may not be aware of!
Great dye, varying intensities possible
By varying the immersion times of this dye, you can achieve a brown "coyote" color to a deep brown, almost black intensity. Great stuff!
Favorite color yet!
This is my favorite color so far, very nice color!
