Brass Plating Kits
Caswell Brass Plating Solution is a unique cyanide-free alkaline brass plating system which plates a true 70/30 yellow-green plate directly onto steel and bright nickel plated surfaces. It can be used for heavy brass plating which will be antiqued (oxidized and relieved). It may also be used for decorative heavy brass if the surface is burnished or buffed and colored with a wheel to remove the slight haze and reveal the true rich brass color for lamp parts, hardware and plumbing fixtures.
To plate on zinc die cast surfaces, you must plate with Flash Copper™ first.
The system eliminates carbonates. Therefore, there is no carbonate sludge containing cyanide to be disposed of.
The solution may be used to tank or brush plate.
Brass tank plating requires an average current of 0.02-0.1 amps per sq. in. and operates in the range of 3-12 Volts.
Brass Plating is available on a small scale using Plug N' plate kits.
4 Gallon Kit Contains:
- 1 x 5 Gal Tank and Lid
- 2 x Brass Anodes (4" x 8")
- 16 Quarts Brass Solution Part A
- 8 x 4oz Brass Solution Part B
- The Caswell Plating Manual
- Free Technical Support
- NO HEATERS INCLUDED
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
