For use with our For use with our One-Plate® 1 Electroless Nickel System.
Use 6.4 fl oz of Boron Nitride dispersion per gallon of For use with our One-Plate® 1 solution.
Solution must be vigorously agitated during plating to ensure the BN particles remain suspended in the solution.
SDS
