Angle Point Detailing Wand
6 Reviews Hide Reviews Show Reviews
Angle point detainling wand
Angle point detailing wand helps to get to tight places for plating repairs.
Perfect for detailing small areas
The Angle Point Detailing Wand makes it easy to apply plating to small areas while allowing me to keep the plating away from where I DON'T want it to go. Perfect for two-tone plating.
Doesn't hold much solution
Therefore, takes time and patience to cover
Great Wand
Out of three wands, this is the one I use most often. Great for getting hard to reach points. Replacement tips would cut down on waste.
Caswell ROCKS!
Tried to make these by hand and just not close to what Caswell offers. Only wish they offered "replacement nubs" with a universal wand. THINK ABOUT THAT! I hate tossing out perfectly good wands only because the nub has been worn down. Otherwise...GREAT PRODUCT and CASWELL ROCKS!
Excellent wand
This wand is shaped perfactly to work on small items and can't reach corners
