Our NEW Aluminum Blue Chromate and Anodize Sealer is a revolutionary product that can be used in the following ways:
- A Non Hexavalent Chromate On Bare Aluminum (imparts a slight blue to purple color on parts) - ROHS Compliant
- A primer for paint and powder coat which results in improved corrosion resistance
- Can be used as a dip, spray or brush on application
- Can be used to seal anodized surfaces at room temperature (not ideal for dyed anodize layers due to slight color change)
When used as a chromate, the coating exceeds the requirements of MIL-DTL-81706B and MIL-DTL-5541F. Parts can be dipped in the solution at room temperature for 5-6 minutes. The solution can also be sprayed or brushed on for touch up in the field.
Procedure For Use As Chromate:
- Clean parts with an alkaline cleaner, such as our Aluminum Degreaser
- Rinse
- Activate (optional with our Aluminum Deoxidizer)
- Rinse
- Treat with the chromate
- Rinse
- Air Dry (24 hours for maximum coating strength)
Procedure For Use As An Anodize Sealer:
- Anodize and rinse parts thoroughly
- Immerse in the sealer for 2-5 minutes at room temperature
- Rinse
- Air Dry
When used as a sealer, parts will exceed requirements of MIL-A-8625.
The solution is used as is. No dilution or mixing is required.
GHS Info
			 SDS
