Alodine 120 Brush on Kit
Gives an iridescent, golden finish on aluminum. Includes enough material to cover approx 100 square feet.
Includes
- One quart of Deoxidine 605
- One quart of Alodine 1201
- Two polyethylene 250 mL breakers
- One nylon brush
Passivates aluminum. Gives a decorative finish, or use as a primer for paint.
