Sander Specifications:
- Sanding pad: 2" (50mm)
- Free speed: 16,000 RPM
- Air consumption: 6 CFM
- Recommended Air Pressure: 90 PSI
- Overall length: 6.5"
- Air inlet size: 1/4" PT
- Air hose (I.D) : 3/8"
- Net weight: 1.8lbs
- CE Certified
- 90 Days Limited Warranty
Kit Contains:
- Air sander #ST-7142
- Wrench
- 5 x 2" Sanding paper
- 5 x 3" Sanding paper
- 1 x 3" Velcro Pad
- 1 x 2" Velcro Pad
- 4 x 2" Surface conditioning disc pad
- Linkup rod
- Plastic Case
