ACRYLIC BUFFING WHEEL 12"
This buff has 16 plies of soft Canton Cloth, carded on one side, to enhance the softness, yet maintain a certain rigidity.It should be used at speeds lower than 1800 rpm to buff acrylic laquers and varnishes. Ideal for buffing wooden instruments, furniture etc. Has metal center and 3/4" hole. Hole size can be reduced to 1/2" or 5/8" with free adapter. Indicate desired hole size below.
good
nice wheel
Good
thank you all was good
