NYLON BRISTLE BRUSH WHEEL 3"
The next best thing to a sand blaster! Lasts up to 10 times the life of a wire wheel! Will not puncture skin Does not shed bristles - unlike dangerous wire wheels Will not rust and maintains its shape
Ideal for:
• Scratch brushing aluminum and other metals for decorative finishes
• Removes paint, corrosion, weld scale, rust & weld marks from steel
• Gently removes paint and varnish from wood.
• Sands wooden moldings, railings, turnings and banisters
• Removes cement from tiles, stone and brick mortar
• Prepares fiberglass, rubber, and all plastics for adhesive application
• Frosts glass
• 3” wheels - ideal for use with a small hand drill.
nice for fins
Precleaning between fins made easy.
