Ideal for patch repairing steel zinc plated items. Plates over steel, pot metal, copper, brass and zinc items. Not recommended when chromating is desired.
GHS Info
SDS
Spare part for kit.
Needed this for continuing plating for many small parts. Found for best results, part must be cleaned completely, still testing other cleaning solutions for best results.
Great stuff!
I didn't realize when I ordered a different brush is required for each metal being applied. Once I got the correct brush I was able to plate with ease. The zinc takes a little longer than the tin I plated with previously. When I slowed down, the finished product turned out great!
