PLUG N' PLATE NICKEL SOLUTION
Plates a solid layer of nickel onto steel, iron, and all copper based alloys. Buffs to a beautiful rich shine.
GHS Info
SDS
17 Reviews Hide Reviews Show Reviews
Great product
Solution works well and plates nickel very well
8 OZ plug and plate nickel solution
Plug and Plate Nickel Solution has been a great alternative to sending parts out for minor plating issues.
Solution
Your product works great. I have nickle plated three pistols dating from 1850 to 1880.
Loved the results!!
I used the dip method and got a very uniform even finish. I continued to put light even layers with the wand as part was submerged in solution. My part had a lot of detail w/ deep recesses!!
Nickel Plating
This is a great product for nickel plating firearms or firearm parts. It's excellent for repairing factory Nickel plating
GREAT PRODUCT
LOVE IT
nice
The best price could find this stuff at i plan to buy i will repost with end thoughts
Great
Good to use if you want to plate gold on stainless steel and you don't feel like using the activator. Works great.
Excellent
Wonderful product, easy to use. I'm about to buy some for the second time!!!
