PLUG N PLATE BRONZE PLATING SOL 8OZ
Plates directly onto steel, nickel and copper. Applies a beautiful decorative bronze finish onto small items.
SDS
6 Reviews Hide Reviews Show Reviews
Bronze is Beautiful
Another beautiful metal plating solution providing a rich bronze plate.
Bronze is Beautiful
Bronze is Beautiful
Overall Bronze Solution
I have found that the end finish on the bronze solution is pleasing light gold when polished.A heavy coat must be applied to achieve this.It is a subtle finish compared to the brass solution which is brighter when polished.
Bronze
Works as described.
Lots of Fun
As with all your solutions, this worked as advertised. It is fun to see the shiny results.
