PLUG N' PLATE SILVER SOLUTION
Ideal for repairing antiques with wear damage, or plating from scratch! Quickly puts a heavy layer of silver just where you want it. Headlight reflectors are easily done with this system.
SDS
10 Reviews Hide Reviews Show Reviews
Great Product. Great Finish. Easy to Use.
This product is amazing and easy to use. Never had a bad plating experience with this product. Since I'm spot plating pretty often I usually have to buy two of these 4oz bottles at a time. Thanks Caswell!!!
Silver plating works great!
The Plug N' Plate system is easy to use and produces great looking silver plating. As mentioned in the documentation, a small bit of smutting (blackening) does occur during the plating process, but it wipes off easily leaving pure, beautiful silver!
Great all away around
Just what I expected. Easy transaction
loved this
Works great, easy to use looks great
worth it
Goes on great easy to use and caswell offers help
works great
This is a great product I highly recommend!
Great product
Works well, easy application, polishes to a wonderful finish. I am really pleased and excited about the things I've been able to do with the Caswell plating products!
Poorly packaged - Product leaked out during shipping.
I like this solution. The plating system works and is easy to use.
Use this for repair of brass musical instruments
Great way of doing silver plating repair. Highly recommended.
