This 30 Piece, Diamond Point Rotary Burr Set makes deburring and shaping metal quick and easy. Use in a 20,000 RPM rotary tool, such as a dremel or die grinder. 3/32" shafts.![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
