100-170 Grit Fine Glass Beads - 50 lb. Pail
All Cyclone Abrasives Are Drop Shipped From The Factory
Several Abrasive Blast Uses
CLEANING
Removes rust, corrosion, and paint witout effecting dimensional tollerances.
FINISHING
While the surface is being cleaned, imperfections and machining marks are blended in.
PEENING
The abrasives pounding effect adds strength to the metals surface, prolonging the working life.
DEBURRING
A moderate deburring effect takes place during cleaning to smooth sharp edges.
FROSTING
A frosting effect will take place on glass and plastic.
ENGRAVING
As you spray the part, depending on the lenth of penetration, an engraving effect will occur.
