Stainless Steel Blackener 370 is an acidic liquid concentrate used full strength or diluted with up to 3 parts water to blacken stainless steel at room temperature. Recommended for color coding parts and blackening engravings on stainless steels. Produces a pleasing dark gray/black finish. Seal with Caswell Sealer.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
GHS Info
SDS
