null
Restoration Aids
RA
  • 100-170 Grit Fine Glass Beads - 50 lb. Pail
    All Cyclone Abrasives Are Drop Shipped From The Factory Several Abrasive Blast Uses CLEANING Removes rust, corrosion, and paint witout effecting dimensional tollerances. FINISHING While the surface is being cleaned, imperfections and machining marks...
    $64.50
    Add to Cart
  • 120 GRIT BROWN ALUMINUM OXIDE 50 LBS
    $104.35
    Add to Cart
  • 150 Grit Brown Aluminum Oxide  50 lbs.
    $104.35
    Add to Cart
  • 180 Grit Brown Aluminum Oxide  50 lbs.
    $207.45
    Add to Cart
  • 220 Grit Brown Aluminum Oxide  50 lbs.
    $104.35
    Add to Cart
  • 40-60 Grit Coarse Glass Beads - 50 lb. Pail
    $68.30
    Add to Cart
  • 60 GRIT BROWN ALUMINUM OXIDE
    $96.13
    Add to Cart
  • 60-100 GRIT MEDIUM GLASS BEADS 50LB PAIL
    $62.61
    Add to Cart
  • 80 GRIT BROWN ALUMINUM OXIDE 50lbs
    $96.13
    Add to Cart
  • Aluminum Brightener
    Aluminum Brightener
    Cleans and brightens aluminum, stainless steel, copper, brass, and non-ferrous metals. In just seconds, the industrial strength formula dissolves grease, oil stains, grime and road film. Dilute 4-6 oz per gallon of water depending on the cleaning job...
    $46.79
    Add to Cart
  • AUTOMOTIVE SOLDER PASTE
    SOLDER-IT silver bearing solder paste in easy to use, no mess, no waste syringe. Soldering made easy - the skill is in the paste. Made from premium refined powdered metals. Ready to use - Flux is blended in, just add heat. No additional flux required...
    $12.64
    Add to Cart
  • SALE
    Casweld™  AL Aluminum Brazing Rod Kit
    Casweld™ AL Aluminum Brazing Rod Designed for joining all brazable grades of aluminum sheet, plate, tubing and piping, extrusions, rod and wire 5 Rod Kit (1/8" x 18") & 2 oz Flux Download our Casweld™ Product Manual Perfect for: ...
    MSRP: $56.93
    Was: $56.93
    Now: $44.00
    Add to Cart
