Protect Expensive Paint Jobs Before Gas Tank Sealing
Water Based Brush On Masking Agent Protects Your Paint Job Against Our Epoxy Gas Tank Sealer
- Safe to use on all thoroughly cured painted surfaces. Surface must be clean and dry.
- Apply with a paintbrush and apply 2-3 coats for maximum protection. Allow 30 mins to cure. Ensure coating is fully dry before mixing tank sealer.
- Washes Off With Soap And Water
- 8 fl oz covers approx 15 sq ft
- Environmentally safe. Does not contain any hazardous or toxic components.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
