A highly agressive wheel for quick cutting and polishing. Ideal for buffing contoured items. Made of tough, long lasting cloth. Use with any cutting compound, or greaseless compound. Very economical to use.
Wheels have a metal center with 3/4" hole. We will add hole reducers to 5/8" or 1/2" on request.
8" Diameter.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
