These miniature barrel platers are perfect for plating batches of small parts in any of our plating kits. We recommend our 4.5 Gallon size kits for barrel plating use. Simply add your parts, submerge the barrel and turn on power to the barrel and rectifier.
Elimates the need to wire up each individual part.
Simply add parts to the barrel, secure, drop into plating tank and turn on.
- 4" x 4" Cylinder - 50 cubic inch capacity
 - Overall Dimensions:
- 14" High
 - 7" Wide
 - 4" Deep
 - Units sits 10" deep in tank
 - 316 Stainless Steel Hardware
 - Choice of Mesh Options:
- C-1 Mesh (0.01″ opening)
 - C Mesh (0.02″ opening)
 - B Mesh (0.03″ opening)
 - 30 RPM Motor - 110 volt AC
 - Requires wiring to 110V plug
 - Ball Dangler
Made In The USA
