Caswell Tinning Solution
Highly recommended when plating over conductive paints. Resolves a mutlitude of problems including patchy plating and eliminates the need for multiple connecting wires to the part.
Adds a conductive coat for high quality electroforming. For better results when using any conductive coating, dip parts in solution for 60 seconds, then plate with Acid Copper.
Use solution at room temperature. No rectifier or power source required. Corrosive Liquid.
Hazardous Shipping Info
GHS Info
SDS
5 Reviews Hide Reviews Show Reviews
Great product
Tinning solution very easy to use
works great & easy to use
Makes conductive paint a snap to copper plate
good shipping
Good product
Delivered on time and works as stated.
good
Pretty good stuff
