Canton Flannel is very soft, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as silver and gold plate. This wheel should not be contaminated with any other compound.Safety Information
excellent
very nice cotton
