Quick view Alumilite sku: ALUM42610 25 X 1OZ MEASURING CUPS MSRP: Now: $6.45 Add to Cart Compare Quick view Alumilite sku: ALUM42710 50 X STIR STICKS MSRP: Now: $6.45 Add to Cart Compare Quick view Alumilite sku: ALUM42620 6 X 6OZ MEASURING CUPS MSRP: Now: $6.45 Add to Cart Compare Quick view Alumilite sku: ALUM20400 ALUMILITE HIGH STRENGTH 2 SILICONE RUBBE MSRP: Now: $35.77 Add to Cart Compare Quick view Alumilite sku: ALUM20500 ALUMILITE HIGH STRENGTH 3 SILICONE RUBBE MSRP: Now: $35.77 Add to Cart Compare Quick view Alumilite sku: ALUM40000 ALUMILITE MODELING CLAY MSRP: Now: $3.59 Add to Cart Compare Quick view Alumilite sku: ALUM20020 ALUMILITE MOLD PUTTY MSRP: Now: $39.03 Add to Cart Compare Quick view Alumilite sku: ALUM42402 ALUMILITE RUBBER TO RUBBER MOLD RELEASE MSRP: Now: $6.00 Add to Cart Compare Quick view Alumilite sku: ALUM10500 Alumilite Super Casting Kit MSRP: Now: $91.06 Out of stock Compare Quick view Alumilite sku: ALSF320 Alumilite Super Foam 320 16 oz MSRP: Now: $22.00 Add to Cart Compare Quick view Alumilite sku: ALUM10010 Alumilite Super Plastic Resin 28 oz MSRP: Now: $39.35 Out of stock Compare Quick view Alumilite sku: ALUM10560 Mini Super Casting Kit MSRP: Now: $39.03 Out of stock Compare Quick view Alumilite sku: ALUM200 Quickset Rubber 1 lb MSRP: Now: $35.77 Add to Cart Compare Quick view 25 X 1OZ MEASURING CUPS 25 x 1oz Measuring Cups MSRP: Now: $6.45 Add to Cart Compare Quick view 50 X STIR STICKS 50 x Stir Sticks MSRP: Now: $6.45 Add to Cart Compare Quick view 6 X 6OZ MEASURING CUPS 6 x 6oz Measuring Cups MSRP: Now: $6.45 Add to Cart Compare Quick view ALUMILITE HIGH STRENGTH 2 SILICONE RUBBE The High Strength 2 silicone mold making rubber is a great all purpose silicone as it is flexible, extremely tear resistant, has a low viscosity that does not require degassing (although always recommended if capable), and is very easy to mix. The High... MSRP: Now: $35.77 Add to Cart Compare Quick view ALUMILITE HIGH STRENGTH 3 SILICONE RUBBE The High Strength 3 silicone mold making rubber is a great for parts with dep undercuts and negative drafts. It has a low viscosity that does not require degassing (although always recommended if capable), is easy to use, and has a very good tear... MSRP: Now: $35.77 Add to Cart Compare Quick view ALUMILITE MODELING CLAY Synthetic Modelling Clay The synthetic clay is used for creating one time original patterns, sealing mold boxes and for claying up two part molds. Alumilite's clay will never dry out and can be reused over and over again. 1 lb MSRP: Now: $3.59 Add to Cart Compare Quick view ALUMILITE MOLD PUTTY Alumilite Mold Putty Alumilite's Mold Putty allows you to make quick impressions without a mold box, in just 5 minutes. It is safe to use and complies with FDA standards for food contact. 1 lb MSRP: Now: $39.03 Add to Cart Compare Quick view ALUMILITE RUBBER TO RUBBER MOLD RELEASE Rubber To Rubber Mold Release Use Alumilite's Rubber To Rubber Mold Release in between pours of silicone rubber to prevent the rubber from adhering to itself. Simply shake the bottle before using and paint the mold release on the cured rubber... MSRP: Now: $6.00 Add to Cart Compare Quick view Alumilite Super Casting Kit Complete Super Casting Kit & Mini Super Casting Kit Super Kit Includes: AB28 Kit 28oz Super Plastic Alumilite Regular 1 lb. QuickSet RTV Silicone Rubber 1 lb. Alumilite Synthetic Modeling Clay 2 oz. Rubber to Rubber Mold Release 1 oz. Measuring... MSRP: Now: $91.06 Out of stock Compare Quick view Alumilite Super Foam 320 16 oz Super Foam 320 Super Foam 320 is an easy to use 2 part expandable foam. It makes reinforcing or casting your own foam pieces extremely easy. Can also be dyed with Alumilites urethane base coloring dyes. The Super Foam 320 expands up to 20 times... MSRP: Now: $22.00 Add to Cart Compare Quick view Alumilite Super Plastic Resin 28 oz Casting Resin Alumilite's polyurethane casting resins allow you to cast exact replicas of an original very quickly. The castings can be dyed, painted, stained, tapped and/or machined. 3 Easy Steps To Using Measure equal parts of A & B Combine and... MSRP: Now: $39.35 Out of stock Compare Quick view Mini Super Casting Kit Complete Super Casting Kit & Mini Super Casting Kit Mini Super Kit Includes: AB28 Kit 8oz Super Plastic Alumilite Regular 1/4 lb. QuickSet RTV Silicone Rubber 1/4 lb. Alumilite Synthetic Modeling Clay 1 oz. Measuring Cups Stir Sticks How-To... MSRP: Now: $39.03 Out of stock Compare Quick view Quickset Rubber 1 lb RTV Silicone Mold-making Rubber 1 lb Kit Base & Catalyst Easy Instructions Included Mixing Ratio 10:1/Base:Catalyst Working Time: 30 mins Cure Time: 4 hours Optimum cure is reached in 24 hours. When Alumilite "Quick-Set" RTV Silicone Rubber is... MSRP: Now: $35.77 Add to Cart Compare Compare Selected × OK
