25 AMP PLATER/STRIPPER
25 Amp Plater/Stripper
This 25 amp unit features a polarity- reversal switch and extra output terminals to speed between stripping and plating jobs. Especially useful when plating auto accessories.
- 0 -12 Volts d.c.
- 0 -25 Amps d.c.
- Continuously variable output control
- 5 way output terminals
- Polarity Quickswitch
- 23 lbs. 13"W x 8"H x 8.5"D
