60 Amp Plater
Ultra-high output plating unit for the most demanding plating jobs.
- 0 - 12 Volts d.c.
- 0 - 60 Amps d.c.
- Continuously variable output terminals
- 60 lbs. 18.25"W x 10"H x 10"D
Â
