RECTIFIER - 25 AMP
25 Amp Plater
Our most popular model. This heavy duty unit will plate larger items. The extra amperage comes in handy for quick electro stripping.
- 0 - 12 Volts d.c.
- 0 - 25 Amps d.c.
- Continuously variable output control
- 5 way output terminals
- 23 lbs. 13"W x 8"H x 8.5"
My personal GO-TO!
I purchased this rectifier used on ebay. I use it for my 10 gallon copper, nickel and zinc tanks. Very simple design and construction and does the job. Has more than enough power for my uses. Also, the internal components are easy to understand and are easily replaced as well, in case servicing is needed.
Very Versitile Unit!
This unit meets all of my shops plating needs. The control makes it easy to make fine adjustments while wearing heavy rubber gloves and the gauges and there placement make for quick accurate system checks. The only thing they could do to make it better is use tougher paint for the lettering, the diluted chemicals left on my glove made the label lettering peal and flake off in just a few months. A great unit none the less just break out a sharpie and plate on!
