RECTIFIER - 10 AMP
10 Amp Plater
This precision built rectifier provides enough power for all plating needs.
- 0 - 12 Volts d.c.
- 0 - 10 Amps d.c.
- Continuously variable output control
- 5 way output terminals
- 17 lbs. 12"W x 7"H x 6"D
