ALUMILITE HIGH STRENGTH 3 SILICONE RUBBE
The High Strength 3 silicone mold making rubber is a great for parts with dep undercuts and negative drafts. It has a low viscosity that does not require degassing (although always recommended if capable), is easy to use, and has a very good tear strength. The High Strength 3 is a tin base silicone. It is recommended for one piece molds, and molds that require a very high tear strength and good flexibility to remove the parts.
