Cerakote Glacier Chrome Oven Cure Ceramic Coating
Cerakote Glacier Chrome is a Revolutionary CHROME FREE High Temperature Polished Ceramic Coating.
It has Excellent sprayability in both high and low humidity environemnts and polishes to an ultra high gloss finish (400 GU at 60*).
- 100% CHROME FREE unlike all other polished ceramic coatings which contain hexavalent chrome.
- Water Based formula eliminates water disposal concerns & costs
- Ships Air & Ground NON-HAZMAT
- Excellent Corrosion Resistance & Gloss Retention at Operating Temperatures. Thermally Stable to 1300*F with Industry Leading Low Thermal Emissivity and Conductivity.
Cure Schedule:
500F to 700F for 1 hour (part metal temperature), followed by polishing in a vibratory polisher.
