Alumilite Super Plastic Resin 28 oz
Casting Resin
Alumilite's polyurethane casting resins allow you to cast exact replicas of an original very quickly. The castings can be dyed, painted, stained, tapped and/or machined.
3 Easy Steps To Using
- Measure equal parts of A & B
- Combine and mix
- Pour - Liquid to Solid in 3 minutes
28 oz Kit
